Alpha one GEN two lube line broke
Boomoo
Yesterday the line broke between the transom in the outdrive is there a check valve in there to stop the water from going into the outdrive I would like to know if I can block it off because I cannot get it in the shop for at least three weeks to a month in the shop we don’t do much driving with it maybe I’ll together maybe two or three hours a day I was told the check valve that will not let water get into the outdrive but I don’t understand that
The check valve doesn't work that way
The valve blocks off lube from draining out when the drive is removed only. With the drive installed, as the drive heats up it will leak lube out thru the transom thru fitting into the bilge. Next thing will happen is drive will be low on lube and damage the drive
Boomoo
Well I’m glad I caught it I drained it out there’s a little bit of water in it and it was a little bit low it just happened yesterday and I probably got 20 minutes on it after the line broke the shop I deal with at another shop can’t get it for three weeks what I’m thinking it was told by his shop that I want her to block it off just keep an eye on the fluid
If its blocked off that's one thing but not blocked off that is another which is what I took as was being discussed
Boomoo
Yes I’m in the process of blocking it off and change the fluid it’ll just be a temporary thing for at least three weeks and I’ll fill it to the line like a regular alpha one
Boomoo
I was working on it at the campgrounds another gentleman come walking up to me and asked me what I was doing and I explain to him what I was doing and he said if you don’t mind I can fix it for you the right way little over an hour later he had a new hose and everything put on the way should be thanks to him I tried to pay them but of course he refused so we’re going to pick up a couple steaks tomorrow and give it to him and his wife
Fun Times
Tell him he needs to become an iboats member in is off time as that is something I'd be willing to bet a lot of us here would try and do to help out like that too.:eagerness: :)
Boomoo
It’s really nice knowing that it was fixed right we just took the boat out on the lake lake Berlin in jOhio and I don’t know if it’s my imagination or what but the boat seem to run so much smoother . The lube did have some water and it had less than a quart of oil in it and it was pretty black , we got a storm coming through here after six days in the 90,s it’s a Relief. 70 now
