When my lower shiftcable is unhooked from the engine, and I push it all inn(from outside), it does not go far enough to engage reverse. I do not get the correct angel on the shift-shaft shoe.. The shaft looks ok, it is not bend, and both the shaft and the cable is operating very smooth. The distance from the 'bellhousing' and the outher 'fork-pin' on the shiftslide is 58mm. (sorry I can't explain this with som images..)<br /><br />The slide can still go some furhter in, but I think it maybe stops in the 'plastic-tube part'.<br /><br />The angel on the driveunit-shaft is ok I think, because it is straight forward when in forward.<br />Can not find anything about this in my mercruiser rep-manual.<br /><br />Any suggestions?<br /><br />mvh<br />Aardal
