Alpha One - How do you access the lower end of the trim pump lines?
JaCrispy
I think I disturbed something installing a float valve and found some oil dripping out of the hull drain. Process of elimination the ps fluid is red, engine oil is gold, but the trim pump fluid is black. Can't for the life of me see under the engine where the trim lines go.
Ayuh,.... The trim lines run from the pump, to the manifold bolted to the transom housin', outside, 'n up-under,....
JaCrispy
So the manifold is removed from the outside with the lines still attached from the inside, there's a gasket or seal for the manifold?
Bt Doctur
