Alpha One - Lower Unit Reinstall
sfree1965
I maybe over thinking things, but I'm sure someone can help me out.
Ok.. I had to replace my upper unit on my 1985 WellCraft AftCabin 230. I got the upper reinstalled with a rebuilt unit. When we tried to re-install the lower unit we keep running into trouble. I've been trying to re-install it according to the manual, attached is a copy.
So, my shift leveler is in the forward position. I not for sure what gear my lower unit is in. According to the manual, if I turn the Shift Shaft clockwise, then the lower unit is in reverse.
My questions;
1. Does my shift lever need to be in the forward or reverse position?
2. Does my lower unit need to be in the reverse position (Shift Shaft) when re-installing it?
Can someone set me straight? Or am I really over thinking things?
Scott
View attachment Boat.pdf
Re: Alpha One - Lower Unit Reinstall
My questions;
Scott
Ayuh,.... Everything, Has to be in Forward....
Yer page is for a Counter-Rotatin' drive,... Not a single screw....
sfree1965
So. My lower unit shift shaft by rotating it clockwise, does does it put it in forward gear?
MarkSee
yes; while holding the lower unit shift shaft clockwise so it is pointing straight fore/aft and turning the prop/prop shaft counter-clockwise it will be in forward. To aid in holding it in forward, wrap a bungee cord around the prop.
Mark
ktbarrentine
Just curious...why did you select the "counter-rotating" section of the manual to do this work?
sfree1965
Thank you everyone. I did exactly what you suggested Mark and everything went together. Ready to put it back on the water tomorrow.
Just curious...why did you select the "counter-rotating" section of the manual to do this work? I don't have a complete manual, just bits and pieces of a manual.
Again, thanks for everyone's help.
Scott
ktbarrentine
We can get you a complete manual here (for both yoru engine and your drive), if you are interested.
