Don S
- Joined
- Aug 31, 2004
- 62,321
Re: alpha one no or very very little water exiting through prop or exhaust relief po
The outdrive is something that should be removed yearly. That is the only way you can grease the coupler splines and check the alignment. You can also grease the ujoints if you have zirks on them, grease the gimbal bearing and clean up the excess grease, and check the bellows for water intrusion.
The drive is only a 10 minute job, put the shifter in forward, pull the trim cylinders off the drive, remove 6 mounting nuts and pull the drive off. It will also take a $5-$10 gasket kit.
It's just yearly maintenance.
I'm in Washington state, no snow, just rain.
you must be loving this mass snow as much as i am.
