massimofinance
Thread starter- Joined
- Oct 30, 2004
- 508
The boat. 2000 SeaRay sun deck with the mercruiser alpha one outdrive.
I’ve recently noticed the buttons that raise or lower the outdrive do not work consistently. I have three buttons. The raise lower button on the throttle, the trailer raise button on the throttle, and the stern toggle switch that is under the stern exhaust vent. If you play with the buttons a bit, they all start to work. Is it the solenoid? Does it just need a cleaning? In this boat, I believe the solenoid is on the trim motor which is on the interior far stern, port side, behind the batteries. I need to remove the batteries to try to get to it, and even then it’s quite difficult. I would appreciate any advice before I start to remove the batteries because once removed, it will be difficult to test out the trim drive. Thank you.
