Alpha one removal!
djmakko
Ok I did it again!! forgot the smallest details, i removed the drive, but reading around found out that when you remove the drive you have to put it on forward position, Well i didn't still came out but, can some body tell me what trouble am I in when i try to put it back?
Don S
Re: Alpha one removal!
It probably bent one of the shift shafts where they mate together. Just look at them, it should be obvious.
crazy charlie
assuming that you did not damage anything and I know many that have done the same removal with no damage,Make sure the drive is in fwd AND the throttle lever is also in fwd when putting it back on.If you seperate the drive then also make sure that the lower is in fwd before you put them back together.Charlie
djmakko
Ok 10-4, I've checked and looks like i didn't damage anything, hopefully goes back together as it should. live and learn, thanks for the help guys.
