Alpha One won't go up or down
gleavens
I can't get the outdrive unit to move up or down. I can hear clicking at the solenoids, but no movement. the last time I used the boat there was no issue, everything worked fine. I can see two solenoids, each with two small posts, what should be happening there as far as power at which post, at which time etc., thanks
Don S
Re: Alpha One won't go up or down
Go up to the adults only sticky at the top of this forum. Download the OEM service manual for you r drive. In the troubleshooting section it give details on how to check the system for problems. Including wiring diagrams.
