alpha one
bmain11
I have an 87 mercruiser 165 four cylinder. I am dumping coolant somewhere. The spark plugs are good and the oil is clean so that would indicate its not a head gasket. Any ideas? Also how does this boat cool itself?
Re: alpha one
Ayuh,... Raw water is pumped by the impeller in the lower unit up through the heat exchanger, 'n out the exhaust riser....
My guess is, there's a hole in the heat exchanger...
