kramerpage
Thread starter- Joined
- Jul 26, 2010
- 447
From reading the manual several times I'm still vague on the sequence. This is for Alpha off the boat on a bench.
Attach 3/4 water hose to plastic fitting above gimbal bearing completed
Install trim senders completed
Install shift cable bellows completed
Install exhaust bellows gimbal side completed
Now the bell housing
Install uj bellows completed
Brass water line fitting completed
Shift cable completed
STOPPED
Now mate them by (all not completed below)
Install shift cable thru shift bellows
Attach water hose
Attach uj bellows to gimbal plate
Attach exhaust bellows
Install hinge pins
Install shift cable fuel type wire tie on bellows
Mount trim senders
Finished
Alot of videos show all the bellows mounted on gimbal plate first but the are gen 2 or bravo with the uj compression ring.
The above list is my interpretation of the #6 service manual.
Please advise and then I will move forwards. Thanks so much.
STOPPED
Attach water hose
Install hinge pins
Mount trim senders
Finished
