alpha to bravo
jaxnjil
Re: alpha to bravo
if it came with the bravo stuff i would think is a bravo. i think your ok.
i could get you more pics of alpha later if your not sure
the alpha is missing the 2 holes you have to drill and is missing the speedometer out let, the fitting for the remote oil reservoir and sea water inlet is cast different.
there kinda the same but the above stuff was different on mine.
i did buy a new bravo T A. if you are using a older used one they might be a little different.
toolsinbox
Re: alpha to bravo
thanks for the link.
looks like i have the wrong trans plate....
grrrrrrrrrr
