cookiesareyummy
Thread starter- Joined
- Apr 29, 2010
- 67
Alpha gen I upper rebuild. I am putting the u-joint bearings back together for the drive gear, I have the style with the small spacer that you have to torque to 70-80ft lbs instead of doing rolling torque. They say to put a hose clamp around the big spacer before torquing which I did and torqued it to 70ft lbs. When I take the hose clamp off the big spacer is still able to slide a little bit. I thought in the past when I did the this spacer couldn't move at all after torquing but it has been a while. Anyone familiar with this being ok or not? Thanks.
