gammalight
Thread starter- Joined
- Apr 13, 2009
- 12
Hello All,
I have a 1986 Stingray bowrider that I purchased 6 months ago. Along the way I have been fixing problems here and there and noticed this problem recently. It does not seem that the battery is being charged while the engine is running. The battery is brand new, I also I have a brand new starter, starter solenoid and slave solenoid. I will charge the battery to about 12.5V and at the end of the day the battery reads 11.9V. If the battery voltage is 12.0 when I start the engine, the voltage at the battery is still 12.0V. From my understanding the voltage should be 1.0V - 2.0V higher while the engine is running,
So I tested the voltage at the voltage regulator. There are 2 wires coming from the stator, one wire going to the starter and another wire going to the circuit breaker and that wire from there goes to the starter as well.
The orange wire coming off the VR going to the starter always reads whatever the battery voltage is.
The red wire coming off the VR going to the circuit breaker always reads whatever the battery voltage is.
One of the red/yellow stripped wires coming off the stator reads a variable voltage depending on what the RPM's are. This voltage is reversed when I put the red lead on it from the DMM. I believe the voltage ranged from -6.0 - -30V from 1000 - 3000 RPM's
The other wire coming off the stator read a variable voltage and was reversed as well. The voltage was not reading as high throughout the same RPM range as the wire above.
Basically with the information above do you think it is the Voltage Regulator that is at fault or is it the Altenator/Stator?
Please let me know if there is anymore information I can provide.
