Alternative heat sources........
roscoe
Re: Alternative heat sources........
craze1cars, interesting, thanks for the details.<br /><br />I talked with friend "Donna" again tonight at work.<br />She said her system was mostly trenched, except for the area up near the house. Her system included hot water heating, and complete in-floor coils for both levels of living space, AND a force air recirc system to keep the loft area at a constant (liveable) temperature. System included all plumbing, floor coils, and is multi zone controlled on each level. So her system is far from typical and required lots of extra equipment and labor to get it right. She also has it wired into her genset for when the electricity goes out.
craze1cars
Yes, Roscoe...radiant PLUS forced air PLUS zoned areas....that's gonna be much more expensive to install than what I've got. $22K is probably very realistic.<br /><br />Bummer it's not working to her expectations...<br /><br />D Grass, your described an "open loop" and it is indeed a true geothermal system and my understanding is that they're equally efficient as a closed loop. They were very popular in the late 70's and 80's when this technology started, and are still sold today. Also very popular for lakefront homes IF it's still permitted...DNR sometimes has issues with that. As you said, they use a LOT of water...about as much as running a garden hose about 20 hours a day, but work just as efficiently as a closed loop.<br /><br />If open loop is permitted in his area, I'd expect this is the cheapest and easiest solution for Bondo and his river. He can pump the water from the river thru his heat exchanger, then pump the water back out to the river. Creates zero polution to the water, just changes the water temp a little bit. Though I'm sure a permit/approval is still required.<br /><br />The biggest negative is that open loops need more maintenance because you have intake screens/filters and periodic cleaning of the plumbing portion. Whereas a closed loop being completely sealed and full of antifireeze will never get dirty.<br /><br />Here's a description I found of all the different "loop" options:<br /><br />"Closed loops, made of durable, high-density polyethylene pipe, are buried in the earth or submerged in a lake or pond. They transfer heat by circulating a solution of water and environmentally safe antifreeze through the system.<br /><br />Open loops use groundwater pumped from a well as a heat source. <br /><br />The decision of which loop configuration to use depends on the terrain, the cost of trenching or drilling, the availability of quality groundwater and the availability of land. Your WaterFurnace dealer will help you make the most efficient and economical choice. <br /><br />There are four basic types of geothermal energy sources: <br /><br />Horizontal Loops <br />These are often considered when adequate land surface is available. Pipes are placed in trenches that range in length from 100 to 400 feet. <br /><br />Vertical Loops <br />These are the ideal choice when available land surface is limited. Drilling equipment is used to bore small-diameter holes from 75 to 300 feet deep.<br /><br />Pond (Lake) Loops <br />These are very economical to install when a body of water is available, because excavation costs are virtually eliminated. Coils of pipe are simply placed on the bottom of the pond or lake.<br /><br />Open Loops <br />These use groundwater as a direct energy source. In ideal conditions, an open-loop application can be the most economical type of geothermal system.<br /><br />For efficiency upgrades where large geothermal systems are not viable, existing boiler/tower jobs are frequently retrofitted. Hybrid systems incorporate a geothermal loop coupled with down-sized conventional heat rejection or additional equipment (a boiler or tower)."
dtherrien
Check out a Rinnai direct vent heater.These are top of the line heaters, that will last for many years.My house is set up for propane and i just recently installed 2...one on the first floor and one in a finished basement.The first one was installed about a year ago and saw a drop in fuel usage imediatly.Now with the both of them, 250 gallons (one full tank) will last about 2 months.
dtherrien
Also....i use propane for cooking and hot water heater.<br />along with energy eff. products....nothing will equal things like replacing old windows with new low-e argon filled ones, more insulation in the attic, replace incadesent light bulbs with new florecent ones and replacing old style doors with new ones.
FLATHEAD
I have a wood and a pellet stoves. Have not turned on the electric baseboard heat for the last two winters. I do 99% of my heating with a pellet stove. 2800 SQ.FT. I use between 3 and 4 ton at about 185$ per ton. It is easy, cheap and a WHOLE lot less work and a whole lot cleaner than wood. Not to mention no fear of a chimney fire or no worries while burning pellets when not home. Very safe way to go.<br /><br />You can burn corn in most pellet stoves but corn is more expensive.
tomatolord
I checked out the thermal systems and carrier has one that hooks into regular heat pump system. It just replaces the outside condensor.<br /><br />The biggest cost of the systems are the trenching costs. <br /><br />THe materials are not that expensive, but the time to have some dig a 4ft trench the lengths that they require is the biggest cost.<br /><br />If you could use a trencher or have access to a backhoe then you should be able to get the cost way way down.<br /><br />The other alternative sources have the problem of working only under certain conditions like only when it is sunnny or when it is windy or the water is flowing. <br /><br />The cheapest thing I could think of would be to build your house on a slab that has water slots/pipes in the slab. Then you could run a solar panel to heat the water that is in the slab to 75 and that would radiate the house....<br /><br />Once you got that mass up to 72 it would not be hard to keep it there.<br /><br />The other fuels like corn and pellets are really local things. Corn here in raleigh nc is not that much more then getting a load of wood and the pellets are not that much cheaper either.<br /><br />These pellet stoves work very well as they have an automatic feeder to keep the fire going 24/7<br /><br />infra red heats objects not air so you feel warm but the air can be cooler.<br /><br />good luck<br /><br />Tomatolord
