alternative oil pan gasket merc 140.
rbuljo
hi all. rebuilding my Mercruiser 140 this week.
but I got a little problem. i can no longer get a hold of a oil pan gasket for my Mercruiser 140, 1986, A401501 here in Norway. and i need to get the boat floating and ready to go on friday.
would it be alright to use "engine sealant", i couldn't find the correct word for it.. but I`ve used this on several cars previously..
but on this engine I can sense a little problem getting it properly sealed in the rear of the engine.
Re: alternative oil pan gasket merc 140.
Ayuh,.... You can try it, but yer chances of success are 'bout Zero....
Bt Doctur
Get some 1 inch wide cork and try cutting one or
Hi-Temp black or Grey silicone , coat the pan or block about 3/16 -1/4 inch
clean block and pan
bamboo shisk ka bob sticks
install sticks as spacers
install pan
GENTLY SNUG BOLTS, REMOVE STICKS AND WAIT TILL SEALANT CURES
tighen pan bolts
rbuljo
ok, thanks all..
Lars0ne
I'll answer in Swedish. A bit esier for me and my iphone. Sorry folks
Jag tror det fungerar med packningsmassa. T?nk bara p? att l?ta det h?rda en stund innan du drar med fullt moment. Hade samma problem med min oljetr?gspackning men jag anv?nde en del av den gammla och "skarvade" in den del som jag inte fick tag p? ny. Se till att fylla skarvarna lite extra och l?ta det stelna. Nu l?r du vara p? sj?n redan. Hoppas du f?r en fin fredag
rbuljo
Larsone, takk. Men jeg fikk faktisk tak i pakning i siste liten. :) 4delt, men ble tett. Takk for tipset.
In English, actually got hold of a 4 piece gasket set in time. And it is not leaking. :)
achris
More fish than mountain goat
I had one of those once, but the wheels fell off... :D :D
Glad you got it sorted.... Happy boating... from the other side of the planet. (I was in Norway 6 months ago, Alesund and Stavanger.... Loved it!!!))..
Cheers,
Chris......
