alternator?
boatman37
have to check it out tomorrow but i'm thinking i may need a new alternator. how do you go about finding the right replacement? is there a catalog to look it up? how about the belts? i want to at least buy replacement belts to keep them onboard but if i replace the alternator then i will replace the belts at the same time. is it a matter of taking the belts to the auto parts store? the one has a marking on it which looks like it might be the part number but the other belt isn't readable. FWIW its a 1986 sea ray 250 sundancer 5.7 merc
Without this we would be asking what are you working on, but still need a engine serial number to verify your part numbers. Without a serial number I'll offer these
ALT belt - 57-93658Q
Water pump and Power steering - 57-37619Q
Could also take the belts to the auto parts store
boatman37
i will try to get a serial# today. i will be headed to the marina later. i will also try to find better #s on the belts. don't want to take the existing belts off to take them into a parts store unless i am replacing the alternator as i don't want to tear it apart unless i need to. the belts look pretty easy to replace so i just want to have spares onboard in case i need them.
where would i find the serial #s? on a small block chevy they are typically on a pad at the front of the cylinder head. i assume they are the same on these? or are we talking about a different serial #? maybe from mercruiser?
UncleWillie
...Have to check it out tomorrow but i'm thinking I may need a new alternator...
You think you May need an Alternator???
Engine OFF ... Battery Voltage = ~12.6v
Engine ON ... Battery Voltage = >13.5? = ALT Good! (>14v is Typical) .... <12.6v? = ALT or connections to it are Bad!
If Bad, Measure at Battery and Alternator, Both readings should be identical.
airshot
Before throwing money into an unkown problem, I would pull your alternator and take it to a starter/alternator rebuilder. Marine units are not cheap and not as well made as original equipment alternators. Do not use a pace like auto zone or other local auto shop....you will need to find a real re-builder that knows what they are doing and they can test it out so you know for sure.
boatman37
thanks for the info guys. i will check it tomorrow. i was down there today but got tied up with other stuff. i did take it out for a quick run. volt meter read about 12.5 but not sure how accurate that is. the end of my multi-meter broke off so made it hard to test it today. going to solder an alligator clip on and try again tomorrow. i was able to check the battery voltage after we came back in by touching the bare wire on the terminals. had about 12.7 on batt#2 (regular car battery) and 10.7 on batt#1 (new deep cell battery). this was with engine off. i ran on #1 on the short trip...maybe 30 minutes.
four guys at our marina have bought alternators from DB electric off ebay and all are working great. they cost about $60 and are marine rated 105 amp'ers. http://www.ebay.com/itm/NEW-105-Amp...ire-/140661477619?hash=item20c013d0f3&vxp=mtr
Your 10.7V bat should be replaced if you cannot get it up after charging.
I bought one of the ALTs from DB years ago, called a one wire. All regulation is done internally. You can get a plug from them to use your current charging setup with the two wires that plug into the back.
boatman37
thanks. the 10.7V battery is new but i was running off that one while we were out so my theory is it ran down with a weak alternator. i did notice at full charge it only reads about 12.0V. a little low but thought maybe cause it was a deep cycle the actual voltage may be lower than a standard battery. i will re-check it today with the fresh charge and hopefully fixed multimeter
i checked for the serial# plate. couldn't see it with the naked eye cause of the location and room to move but got a recording with my phone but its too blurry. but i did see the #'s on the PS belt and it is 57-37619. i will be trying to get more info today and try to get the #'s off the plate.
also, talked to the PO yesterday (he bought the boat new) and he said he thinks that alternator is the original (~600 hours and 30 years old)
Fully charged 12V battery should read 12.7V off charger and disconnected from everything
boatman37
k. both batteries read 12.7 engine off charger disconnected. engine running they read 13.6. so seems alternator is not a problem. also, got the serial# off the block. A593759. it may be A583759 but pretty sure its a 9. i did get both belt #s too. 57-37619 on the PS and 57-93658 on the ALT
boatman37
another question. just read a post about battery isolators. mine has an isolater. my plan is to run using my regular 'car' battery (#2) and when anchored i will use my marine battery (#1). does any of this matter with an isolator? i do not have an onboard charger but bought a battery tender and leave it plugged in 24x7 at the marina using shore power.
A tender will not be able to charge up a battery, tenders are used for tending only, max 1 amp or so. Trying to use them to charge a battery will burn them out over time. Now if your tender can put out more then 3 amps it should be fine, but will take a awhile to charge a battery if it is down 76% or so
