Re: Alumacraft Restoration
Jim:
I'm working on an old aluminum boat as well. I pounded the rivets tight with my daughter holding a bucking bar (block of steel) on the rivets inside. Then I used 2 coats of GluVit on all interior seams and rivets per instructions. This stuff is no UV stabalized so it needs to be covered or painted.
Then for good measure I sanded the outside (just to remove sheen, paint was on pretty good). Then I primed any bare aluminum with zinc chromate primer and applied 3M 5200. I allowed this to cure for a week before painting over them when I painted the hull.
Lot of work, but I really want a dry boat.
Best of luck,
Jim
