Alumi-Weld or Durafix
Azlo
Has anybody tried this to fix their hull or anything else. Alot of good reviews.
alumiweld u can get at harbor freight. Instead of welding u can braze?
Starcraft Enterprise
Re: Alumi-Weld or Durafix
I used alumaweld to patch a jon boat once. It was not pretty, but it did hold.
I tried propane first but could not get it hot enough. Had to use mapp gas. Hull was at melting point before I could get any flow. Is not as easy to use as in infomercials. Worked decent on bullet holes. When I patched a rip in the bottom, it would crack when it cooled due to thickness of the patch. I would not use it on my Starcraft. It is worth the expense to pay somebody to Tig weld it for you.
JimbC
Well I won't be needed to use it. My BIL is gona do all my aluminum welding at his shop. The best part is it will be freeeeeeeeeee.:D
Azlo
I used it this week end to no real yields. I just couldn't get it to stick strong enough. I think its easier and faster with jb weld. The pics are for braces for my hull, i just decided to rivet them together. Maybe i need more practice.
JimbC
Just curious did you tin<(spelling) the pieces first like they do in the video with the little brush.
mea01
when you weld aluminum it has to be cleaned with stainless steel brush really good
Azlo
Yeah I used the stainless steel brush for like a minute, set the brush in a clean place and then even tried thinner clean the pieces and then brush. hmmmm
insanity
Tig welding aluminum is hard, if you contaminate the electrode results are in the pictured above.
