I'm working on an aluminum boat the front of the boat leaks. I had painted all the rivits with gluvit last summer (never used the boat though)
I filled up the inside with water today to check for leaks.
The keel in the front leaks down in the area that's painted gray. No rivits appear to be loose
If you look in the pics, you can see from inside the boat, it's 2 pieces of sheet metal with a keel strip riveted to it. Then in the upside down pic, you can see that red line along the keel, it looks like some kind of caulk, There's some cracks in that and water is dripping out. I don't know if I'm supposed to caulk it from the outside our try and run gluvit or something down between the panels from inside the boat.
Any suggestions.
Thanks,
Nick
Any suggestions.
Thanks,
Nick
