Aluminum extrusion trim sources?
ShoestringMariner
Hey guys, does anybody have a source for aluminum extrusion trim pieces? I have found some nice extruded aluminum angle pieces at Home Depot but nothing like these.
I know I’m looking for a needle in a haystack here, but I would like to find some of the small channel that trims out the interior side panels as I’m going to be extending them into the consoles. If not readily available I can bend some up, but the outer corners will be rounded. I really like the crisp look of extruded.
Watermann
My local fabrication and welding shop had a whole bunch of different Al in all shapes and sizes. Not sure any was small like you want but if you have one locally it's worth a look.
MNhunter1
I've had good luck with Orange Aluminum.
ShoestringMariner
Thanks I deal with a lot of metal suppliers. I’ll check with some of the specialty alloy houses. But most of them around here are more industrial-based
