aluminum wheels stuck to hub
KJM
I had a flat yesterday on an old dirt road. The rear tire an my f150. The tire was very hard to get off. I eventually had to get a big rock and repeatedly beat it against the rim. This tire had been on there for a few years. I know people put grease on there when changing tires, as do I, but you would think there should be a better way? Like some kind of gasket or something to create a physical barrier. Any thoughts or remedies?
Rotate tires every 5000-10000 miles
Antisieze on the hubs ( just don't put it on the brake rotors)
KJM
Loosen the bolts.-----Move vehicle a bit.---Jam brakes .----3x and wheel will come off easily.
Only problem was the wheel was flat! But I have heard of that before.
Renken2000Classic
How'd the aluminum rim weather that?
I've got a front hub/rotor (RWD truck) that apparently is out of tolerance because wheels stick on it. I add just a little grease if I remember to.
Getting them off is a heavy rubber mallet or deadblow hammer on the inside sidewall of the tire while rotating the wheel.
briangcc
Grease on the threads and seating surface of the rim...when I was younger and did the rotations myself. I'm old(er), fat(ter) and have kids so I let the next generation do my oil changes and tire rotations now.
I carry a trolly jack so if it was to happen now, I'd loosen the lugnuts a bit, raise the vehicle, then let her slam down on the ground. Should be enough force to dislodge a stuck wheel.
KJM
The rims didn't like it one bit........
Bob_VT
I use a palm sander and smooth out the mating surfaces of the aluminum wheels...... apply never seize and done. I also use the spare tire as a weight - swing it into the flat and there is usually enough mass to help get a stuck wheel off. Got to love living in an area where salt and liquid chloride attack everything
  • Like
Reactions: KJM
KJM
Using the spare as a mallet seems like a good idea!
Ayuh,...... I quit using never-seize after many head butting sessions with Don S,......
I now slather 'bout anything I hope to take apart someday, with Perfect Seal, aka: form-a-gasket liquid non-hardening,.....
No doubt, the greatest knowledge gift I got from Don S,..... ;)
KJM
I might have to try that!
Lou C
I have used antiseize on the hub area of aluminum wheels on our vehicles for years without problems, never had a rim stick on a rotor or drum.
Now on the boat trailer that goes in salt water I use Evinrude triple guard grease instead. I had heard that antiseize could cause problems in salt water depending on the metal you’re putting it on & the the type of antiseize. Regular antiseize has copper & nickel in it but aluminum antiseize does not. On fasteners on the outdrive all I use is Evinrude gasket sealer.
If you want to use antiseize on the alu rims on your vehicle just use the alu antiseize.
Ayuh,..... Believe me,.... Once you do, you'll never go back to grease or never-seize,....
I've still got the bottle of never-seize I was using years ago, when Don S finally beat into my brain that Perfect Seal works, where grease or never-seize disappears over time,....
Honorary Supreme Mariner
Oxygen joins with the aluminum in the presence of water ( salty water ) and forms that white powder.-----So nature puts more material in there ( oxygen ) little by little and jams it up.-----So yes , if you keep moisture and air out of the joint you will be golden !
Chris1956
I would think Fluid Film would work as an anti seize in that application.
I use permatex #3 (aviation) on all machined joints and as both an anti-sieze as well as a sealant for fasteners. I use it on gear box surfaces, seachest threaded connections, all the bolts exposed to both salt and fresh water, and a few other things
for exhaust bolts, I use maalox.
Grub54891
My neighbor can open a can of anti-seize and even if I don't go over there, I get it on my face. lol
