eavega
Thread starter- Joined
- Apr 29, 2008
- 1,377
Hello to all
I have a QD-21 (Johnson 1960 10 HP Sea Horse) that I acquired about two months ago. I have done the following work to it:
1. New spark plugs
2. Impeller replacement
3. Cleaned and rebuilt carb
4. Changed LU oil
5. Inspected coils
6. Gapped points
Apart from that, I did some other necessary repairs like replaced the recoil starter spring (snapped) and the prop nut (damaged it while trying to remove the prop for inspection)
I ran it in a barrel to make sure it would start and was pumping water and cooling properly.
Last weekend I finally put it on the back of my boat and put it on the lake to make final adjustments on the needles, and just to see how it would perform.
I have a 14' Valco semi-vee fishing boat. Plate on the back says its rated up to a 25 HP motor, max weight in the boat of 950 Lbs. The boat itself is probably about 150Lbs-200Lbs. I would estimate I had about 500 Lbs to 600 Lbs in the boat (myself, electric trolling motor plus battery, seats, 4 gal fuel, tools, and fishing gear), heavily weighted to the stern (fishing gear, 3 gals of fuel and some of the tools were in the bow, everything else was in the back)
The motor started cold with choke pulled out in 3 pulls (primed until the squeeze bulb got hard). I shut down and restarted the motor probably a half-dozen times, longest interval between restarts may have been about 10 minutes. Longest interval of running the motor without shutting down was probably about 20 minutes. Started on first pull on each of the restarts. Motor smoked some at first (expected, b/c I had sprayed each cylinder with Deep Creep back when I was working on it), but by the time I was heading in, it wasn't smoking any more than I would expect from a 2-cycle motor.
Now, here's the problem; with the throttle twisted as far as it would go, the boat mustered a whole 6 MPH, measured with a GPS. That was after I trimmed the motor up to try and get the bow down a bit. The motor ran smooth, would rev up and down in response to twisting the throttle, did not bark, hiccup, or hesitate.
As the title implies to my post states, though, am I wondering if I am expecting too much out of this motor. Should I be happy that it is running smoothly, but doesn't pull the boat very well? What are some of the possibilities for smooth running with no power?
My next steps:
I have a "tiny-tach" on order, b/c I don't know what the RPMs actually were on the motor at WOT. That is my next check.
When I have it on the water again (next weekend), I am going to check to see if I have a cylinder that is not firing. I checked the spark when I changed the plugs, and I get a nice blue-white spark. Given that is is running fairly smoothly, I would think that both cylinders are firing. Granted, I did not change out the coils and points, but the coils did not appear cracked or even old, and I was getting good spark. I haven't changed the coils b/c this involves having to get a harmonic puller, and the budget is a bit thin for one of those plus the parts I need, and I was avoiding it if possible.
The prop on the motor is probably the one that was originally on the motor when it rolled out of the factory in 1960. There is nothing obvious with the prop, but you can imagine is has some wear on it.
Anyway, any insight, observations, or reality checks would be appreciated. Thanks for reading my long post.
-Eric
1. New spark plugs
4. Changed LU oil
5. Inspected coils
6. Gapped points
My next steps:
-Eric
