Am I screwed? 86 60hp Mercury Flywheel Removal/Timing
Pholla10
So I am completely new to outboards and I have been working on this older 60hp for my bass boat. When I removed the flywheel in order to replace stator and trigger, I pulled all of the smaller bolts and the large center bolt. I did not mark exactly how the flywheel lined up, and about 20 minutes later I realized that I may have screwed myself. I have put everything back together and finally got the motor started. How can I tell if my timing is going to be messed up? and If it is messed up, How can I fix it? Thanks in advance
oh and btw, the serial # is A140948 1986 Merc 60hp
Re: Am I screwed? 86 60hp Mercury Flywheel Removal/Timing
You can often look at the rust / stain marks and put it back together in perfect order.--And you are not the first to make this mistake.
jslu
How can I fix it?
Simple!
Ignition off.
Remove all the spark plugs.
Stick a pencil or something like that into the top hole, usually No. 1 piston.
Hold the pencil against the top of the piston and rotate the flywheel by hand.
When the No. 1 piston reaches the top of it's travel (TDC), your timing pointer should point at 0 on the side of the flywheel or wherever your timing marks are located.
If not, remove all bolts and reposition flywheel and try again.
I have a 1987 35HP Merc and this works for me.
John
Faztbullet
I see this posted alot...here is quick way to reassemble. Put your reference mark (.462-464) at 12:00 and key at 5:00(looking down on flywheel) and install bolts.
Pholla10
Thank you guys so much, feels good to know I'm not the only one haha. I will try the above methods tommorow.
Pholla10
Ok tried your guys methods finally after all this damn rain! I think I am good to go now. Motor sounds alot better and hopefully I can get on the water soon.
Mrbap
Newbie boater Question: Im in the same situation as the OP. The flywheel is “keyed” but does that mean the timing still need to be reset? MANY THANKS! I have a ’02 Mercury 40hp efi bigfoot.
JDusza
Timing light. All cylinders.
What's the data say?
J
