Good morning,
I've been playing with this free 150 hp Mercury outboard and have finally got it rewired to manufactures specs. It now turns over without any problems. I plan to test the motor after I replace the 5/16" fuel lines as they are now leaking badly. I'm sticking this motor on a friends 28' party barge which has Mercury cabling already installed so everything should match up. My question is about the amp gauge. This boat has an amp gauge in the dash with no wires hooked up to it. I'd like this to work to verify that the motor is recharging the battery. Are the wires supposed to come off the key "run" position and then down the cabling to the switch box? I have purchased a factory service manual but no where does it mention how to wire in this gauge. Thanks, Bob
