Amp question on 2005 90hp tldi
gvnitup
Bought a new boat found that the battery will go dead over the weekend. I have found that if you unhook the main battery cable (Ground of coarse). It will spark as soon as you reinstall it.. Could there possibly be something wrong with the engine? Nothing else is on, I have twomain switches, I know the eecu will draw some power, Normally the draw is gone once initial power is installed. Any ideas??
TOHATSU GURU
Re: Amp question on 2005 90hp tldi
There is no draw at all from the engine when it is turned off. Think in terms of a bad battery or something else is pulling the power.
