Amsoil Saber Outboard 2- cycle oil 100:1 mix
Status
Not open for further replies.
Gman 82 aquasport
Has anyone used or is using Amsoil 2 cycle Synthetic oil in place of TC-W3. The Johnson dealer here that I deal with is trying to talk me into trying it, says he uses it and alot of his customers are starting to use it. It's mixed 100:1 no matter what , can only be used premix (which I do).According to the jug, you mix 8oz to 6 gallons of gas, being synthetic it is supposed to lubricate better and not foul plugs.Trying to get a feel if this is worthwhile or snake -oil. I have not put it in tank yet, but am willing to try it if I can get a read on if it really works at 100:1 and won't hurt the motor.....any info will be appreciated..
D
DJ
Guest
Re: Amsoil Saber Outboard 2- cycle oil 100:1 mix
Oh Boy! Here we go!
Ask the dealer to warrant it. In writing.
nwcove
ask your johnson dealer what would happen if you bought a new motor, used amsoil at 100:1 and your motor failed due to lack of lubrication, if he tells you that it would still be covered under warrantee, find a new dealer! allow his "other customers" to try the experiment with mixing 100:1 no matter what!
hidef
I wouldn't run it in my outboards at 100:1 I don't care what Amsoil says because at the end of the day they are not going to replace my engines if they fail. The book calls for 50:1 and that is what you should mix it at.
JB
This topic has been beaten to death a hundred times. Not this time
Status
