boat_beginner
- Joined
- Dec 25, 2011
- 73
I'm trying to determine what size prop I need for my boat, a 24' pontoon.
I have a 1973 85hp Evinrude on it right now, running a 13 1/4 x 17 aluminum prop, and turning at 3100 rpm WOT. I'm not to sure of the exact speed, but its abound 16.5mph, I don't have a GPS on the boat to know exactly, and don't have any plans to buy one, so that is based off an iPhone app while underway.
From what I have gathered, the motor has a 2.0 gear ratio, and should be around 4500-5500 rpm. I would like to get at least 5000rpm if possible.
I am coming up with a 9" pitch to get my at 4700, which isn't quite where I would like it to be. I have found a new prop on eBay, that is a 14x9. I considered trying it, and if its still to much pitch, have it repitched lower, but a 9" pitch seems almost to low. Am I wrong?
There is also a 4 blade, which I would much prefer, but the pitch is to much to even have repitched.
14x9
http://item.mobileweb.ebay.com/viewitem?itemId=190723937127&index=0&nav=WATCHING&nid=87020691952
4 blade
http://item.mobileweb.ebay.com/viewitem?itemId=290925597542&index=2&nav=WATCHING&nid=12502676907
There is also a 14x11 mercury prop I have looked at, but I'm not sure if I can have a different hub put in so it can fit an evinrude motor. And it is an 11" pitch, which i believe is to high, so repitch it. Does anyone know if I can re hub it to fit an evinrude? And the mercury prop almost looks more like a "pontoon" prop, with the larger blades on it too.
http://item.mobileweb.ebay.com/viewitem?itemId=321107109127&index=4&nav=WATCHING&nid=34389173393
14x9
4 blade
