anchor chain size
agallant80
25 foot cruiser clocking in at about 7200lbs. What size chain should I get for the anchor?
Grub54891
Re: anchor chain size
Does it have a windlass? You have to match it to that if you do.
JoLin
What grub said. If no windlass, 1/4" chain and 1/2" line will be fine.
Home Cookin'
how you rig it (length, etc.) depends on how you will be using it. The "formulas" are for overnight unattended anchoring in open water in a storm (ie worst case). That may be an important safety factor for you.
And for safety reasons you need the worst-case rig if you boat near the NC ocean inlets; if you break down it is essential you stay put.
crabby captain john
It should be no problem staying in NC inlets. Most are in such bad shape he will be on a sand bar.
