anchor for RIB
ssobol
I need a recommendation for an anchor for a Zodiac 470 RIB. I really don't intend to use it much, but probably should have one just in case.
This anchor will probably be Danforth style so that it can lie fairly flat in a compartment.
I just don't know how big (weight) it should be.
I usually boat on large rivers, inland lakes, and inlets on the Chesapeake Bay.
Thanks.
Sea Rider
Re: anchor for RIB
Whatever anchor type you choose, use at least a 1.5 meter lenght 6-8 mm stainles steel chain betwenn anchor and rope for the anchor to lay properly at sea bottom.
Happy Boating
Re: anchor for RIB
Hi
A folding grapnel anchor is often recommended for smaller RIB's as their design is less likely to mark or tear the tubes. A 5kg grapnel on 10ft of chain with 20ft of line should do the job for a 4.7m RIB
Jurassiccoast
Sea Rider
Re: anchor for RIB
You should use an anchor model and weight that best secures you boat to a beach, lake, river bottom, not all anchors performs the same, if cautious can use any model on board.
Happy Boating
Syzygy
Lewmar Claw - 1 kg anchor at Defender. Plenty of holding power
Just saw that Defender got in a small claw anchor that would be perfect for small RIBs. Lots of holding power in a tiny anchor. Lewmar claims it will hold up to a 20' boat.
Selling them for $8.00 is what I am told. They had about 100 of them in the Store.
Lewmar Link: http://www.lewmar.com/downloadcatalogue.asp?lang=english&id=7447&lid=23581
Cheers
