rfdfirecaptain
Thread starter- Joined
- Aug 17, 2008
- 314
I snapped the anchor roller off the pulpit of my boat (Crownline CR250, 1993 model) this weekend while trying to dislodge the anchor. There is no damage to the boat or the anchor roller. The holes on the deck side are also 5/16 holes, therefore a molly bolt system was definitely not used to mount the anchor roller from the deck side. I can see where the threads on the 5 inch long, 5/16 mounting bolts are stripped off the lower 1 inch of the bolt, which led me to believe that a nut had likely been stripped off them as the bolts pulled through. So, I called the boat manufacturer (Crownline) and determined that the anchor roller was mounted on the top deck using through bolts with washers and nuts at a minimum, and possibly a mounting plate for reinforcement underneath.
These are the questions I have.
1. Can I access a hollowed area in the pulpit to replace the bolts, washers, nuts etc? by removing the mirror at the front of the cabin? I know this gives access to the anchor locker, but I?m not sure if there is access into a hollowed pulpit area.
2. If I cannot remount the anchor roller by accessing a hollowed pulpit from the anchor locker I am considering another option other than a molly bolt system. Has anyone ever mounted an anchor roller using bolts that penetrate the deck side and exit on the hull side of the boat, using a stainless steel plate for reinforcement on the hull side? This suggestion was given to me by the manufacturer (Windline) of the anchor roller.
Thanks,
Keith
Thanks,
Keith
