Re: anchor
Vessel anchoring is part science, part intuition, part experience, and part voodoo. The anchor weight, design, angle of flukes, and scope of the anchor rode (determined by its weight and length relative to the water depth) all come together to make for a secure anchor. And all of that is relative to water movement (if any) and wind
which is relative to the shape and size of your vessel.<br /><br />There is no
one-anchor-does-it-all anchor, but the closest thing to it is the Fortress brand of Danforth type anchor with adjustable fluke angles that improves holding in sand and mud. But I think your best bet is to start with someone elses experience and go from there. Who has a boat that is similar in size/shape as yours and boats in the area you are in? What are they using for an anchor? What anchor rode scope do they use? Thats where I would start.<br /><br />Electric windlass under $1000 were evaluated in the Feb 2004 issue of PowerBoat Reports, and revisited again this month in the July 2005 issue. To properly size a windless for your boat/anchor setup, you need to know how much pull you need. For that you need to know what size anchor, what kind of anchor rode, how long/heavy, etc...<br /><br />You didnt think this was going to be easy, did you?<br />
