Anchor
5chev5
this is my first boat and I am just wondering what size of anchor would I need for a 17 ft chris craft, thanks
tashasdaddy
Frank Acampora
Re: Anchor
Generally speaking, a Danforth type fluke anchor is a good all-around choice. If anchoring to fish or picnic, a 4 pound fluke "lunch hook" with 3/8 inch nylon line will be sufficient--but just sufficient, assuming gentle current. Longer or more secure anchoring would call for an 8-10 pound danforth type. 3/8 line is still ok but 1/2 would give an extra margin of safety --more expensive to buy, and more difficult to handle. Not really necessary on a small boat like that for an afternoon. With either anchor a minimum of 6 feet of chain at the anchor to absorb bottom chafe and to help set the flukes is necessary. Use a thimble to absorb strain and splice the rope around it to the chain. For an anchor, don't consider anything else but nylon line. Poly is cheaper, but does not have the strength, UV resistance, or longevity. Does not hold knots as well either. Carry 7-10 times (in length) the depth of the water you intend to anchor in plus the height to the cleat. Example: anchor in 2 feet of water, with the boat cleat 2 feet above the water is 4 X 7 +28 feet of line and chain. Carry a minimum of 50-100 feet though.
Of course, if you will primarily anchor in a specific type of bottom then buy the anchor designed for that type bottom. The retailer should know which is best for your area.
dave11
Re: Anchor
I like the fluke style anchors. I get an anchor one size larger than indicated so I don't have to be as concerned about it coming loose.
lorenbennett
Re: Anchor
Personal problems with waking up drifting (another story sometime) I like the box anchors. They work great and give me peace of mind at night. I have the standard windlass mounted anchor and I will drop the box anchor also.:)
m&m252
Re: Anchor
just dont try a cinder block and manila rope...i was only 14yrs old not much$$$ had to anchor sometime it worked for a while....
Boatist
Re: Anchor
I have anchors from 4 pounds to 12 pounds and even some heavy Navy type.
My Favorite is the 4 Pound Fortess FX 7. It Digs in faster and holds better than any other anchor I have and is the lightest. I only have 3 foot of 1/4 Stainless Steel chain and 300 feet of 5/16 anchord rode. I keep two anchors on the boat but since I got the Frotress FX-7 have not used the 8 pound danforth.
Frotress FX-7 is rated for boats to 27 feet.
jtexas
Re: Anchor
on the lakes around here, I find that 4 ft of chain and 2 to 1 scope is adequate with this "chene" anchor, even in high winds:
except hardpacked sandy bottoms seem to a require a bit more scope. that's just anchoring to fish, not for overnight or anything.
