Sea18Horse
Thread starter- Joined
- Jun 1, 2008
- 626
Well, a little different anyway.
I'm doing a restoration on my drift boat. A 1983 14' ClackaCraft. In comparison to the other restos we see on here this is a very simple project. But since the pacific nw in general and driftboats in particular are severely under-represented on here I thought what the heck!
I usually hang out in the Johny/Rude outboard section so this will be more or less my first post in this section so greetings!
First order of business was to go through the trailer. Here is an overview of the boat before I started.
. I don't have a very good overview of the trailer after I went through it last summer But this shows the winch stand and the spare tire ok;
. The winch that I inherited from my grandfather is solid brass from Albina engine and machine works right here in Portland Or. They made landing craft used in WWII as well as tug boats and other kinds of work scows. I still need to find a way to secure it better. I shudder to think what's going to happen when the tweakers at the boat ramp see the 5 lbs of solid brass!
My two main points of concern were the transom and the fiberglass doublers or stiffeners in the floor/hull.
Here is an overview of the transom;
. The transom is mostly the wood on the outside. The core was just 1/2" structural foam sandwiched between layers of fiberglass. Great for strength but not so good for crush factor with the through bolts and the transom clamps.
The stiffeners on the floor were also structural foam core with fiberglass laid up over it. After years of being walked on it was all cracked and the foam soaked.
To be continued;
Cheers.................Todd
. The winch that I inherited from my grandfather is solid brass from Albina engine and machine works right here in Portland Or. They made landing craft used in WWII as well as tug boats and other kinds of work scows. I still need to find a way to secure it better. I shudder to think what's going to happen when the tweakers at the boat ramp see the 5 lbs of solid brass! My two main points of concern were the transom and the fiberglass doublers or stiffeners in the floor/hull.
. The transom is mostly the wood on the outside. The core was just 1/2" structural foam sandwiched between layers of fiberglass. Great for strength but not so good for crush factor with the through bolts and the transom clamps.The stiffeners on the floor were also structural foam core with fiberglass laid up over it. After years of being walked on it was all cracked and the foam soaked.
.To be continued;
