Re: Anode Replacement
the zinc is that thing at the bottom thats looks corroded and its white?
whats that thing do?
When dissimilar metals are in contact with each other and they are surrounded by a electrically conducting fluid (water with minerals & dissolved salts for example) an electric current is created...a battery. In this process, the weaker metal in the galvanic series is eaten up in the process. Outboard motors have a lot of dissimilar metals (i.e alloys of aluminum, stainless steel, etc.).
To prevent the motor from dissolving in the process, engineers added an extremely electrically weak metal to be dissolved in the process (the zinc) instead of the motor. It's always the weakest to go first!!
In essence, you can do the same and make a battery with any two metals that are different, connect them, and put them in saltwater. Depending on the which metals are used and the amount of time, you can see the "weaker" metal dissolve.
Obviously, engineers at Duracell have perfected this process!!
MAS
