Anodes
GasCan II
Hello every one;
I was just thinking about ordering a new set of anodes for my Bravo II drive. I run/ slip in saltwater so I use aluminum anodes ( per MC) on the drive. Should I use aluminum anodes on the S/S trim tabs ??
Thanks.
MarkSee
Re: Anodes
I use a round 2" aluminum anode on my trim tabs and see no deterioration of the tabs; only the anodes as there should be.
Mark
HT32BSX115
Re: Anodes
Hello every one;
Thanks.
Make absolutely sure your Mercathode is working properly!
GasCan II
Re: Anodes
Thanks for the replies, and HT I will check out the Mercathode unit !
Thanks Again
tazrig
Re: Anodes
Mark
I used the 3 or 4 inch on my tabs (sanding the tabs under the anodes first for the best connections) with the same results tabs were fine lasted 21 years and the anodes were always toast after just 4 months in the water.
