SDSeville
Thread starter- Joined
- Mar 19, 2010
- 1,486
Re: Another 470 Leaking Coolant
Thanks for the advice guys. However, I was not able to salvage the oil pan gasket. I tried and tried and even broke a razor knife in the process, but the gasket pulled right off with the timing cover. Even though all my razor work was on the top of the gasket, it pulled cleanly of the pan instead of the cover.
When I pulled the timing cover, I found that someone had replaced the seals before. However, instead of using speedi sleeves, it looks like they used 2 gaskets in order to change where the seals ride.
Some nice scratches in the timing cover from when the PO replaced the seals. The seals aren't even in there straight. This one is only bottomed out on one side and sits about 1/8 to 1/16" off on the other.
