another aluminum boat question
txmntman
I'm restoring a 1967 Starcraft. All aluminum boat, and I'm about the add the foam and install the deck. I've heard people using SS screws to install the deck on the the aluminum stringers. However, SS causes problems with aluminum (so I've heard). I don't see how you install a wooden deck onto aluminum stringers without the SS screws coming in contact with the aluminum. Are you using rubber washers or something to insulated the two dissimilar metals? Some insight here, please.
gcboat
Re: another aluminum boat question
Ever think about using an aluminum screw?
txmntman
actually, I have. I have not found a source for them for sure, they are hard to find, but are apparently made. They would not be near as strong as a SS screw, but I would not have any corrosion problems. I was just wondering what others were doing and if I was worrying too much about the corrosion issue.
gcboat
www.aluminumscrews.com
There's one place to start looking. My ACE Hardware carries a bunch of them but I'm on the ocean so maybe it's just a store to store thing. I really wouldn't worry too much on the corrosion issue, even in a salt water environment after a good rinse the thing should last a long time. Longer than you'll probably want to keep the boat. :D
Tell me what size, type of head and how many - I'll send them to you. Just send me a PM unless you want the world to see your home address. :eek:
Ayuh,....
Why wouldn't you use aluminum Pop Rivets like Starcraft did,....
That's how I put mine back together.....
Screws will loosen,+ fall out,.... Rivets Won't......
txmntman
I guess I'll show my ignorance again. I guess I don't know how to effectively use rivits connecting wood to aluminum. I used them aluminum to aluminum, but not aluminum to wood.
Ayuh,.....
Same function, just thicker material.....
I used 3/16" rivets(the Fat headed 1s), 3/4" long, thru 1/2" plywood.....
Coors
Google the rivets and tools- they can be bought locally.
JimMachinery
Bond-o:
I'm going to be doing the same thing soon on my 1967 Naden Aluminum boat (16' runabout). Did you use pop rivets? if so, how did you seal the holes?
Thanks,
Jim
kevsuperg
used deck screws (home depot)saw that somewhere in these posts,with finish washers,have a dimple in the middle for the screw head,i screwed right thru my carpet and 1/2 ext ply so no glue and easy to remove.
rtn
For fastening the wood floor to the aluminum bulkheads we used pullthrough pop rivets and or screws with a finishing washer. Decks etch were fastened to the gunwales with stainless steel screws, we had no problems with corrosion.
rtn
TerryMSU
For all those fasteners, McMaster-Carr has all kinds of fasteners. Web site is "www.mcmaster.com". From my experience, they have great service, fast shipping, and reasonable prices.
Terry
Ayuh,.... I used Pop-Rivets,+ covered over them......
It's more important to allow the bilge to Drain, than to Seal everything up......
