Another anode question???
seabob4
Re: Another anode question???
On the sides of the LU just above the cav plate
limitout
Banned
there should be two similarly shaped indentions above the cav plate at the rear of the "tail" portion, there may be grey plastic "filler" pieces there just to make it look nice and you remove those to be replaced with the anodes but if for some reason your motor doesn't have these then it wont fit.
this is what it might look like: Clean 2001 Johnson 25 HP Short Shaft Electric Start Tiller Outboard Motor | eBay
there is going to be something similar for yours but if nothing is visable then your motor may use the trim tab style anode where the trim tab itself is your anode like seen here: Amazon.com: TRIM TAB, ANODE, Al | GLM Part Number: 12676; Mercury Part Number: 822157T2: Automotive
Fed
On the lower side of the AV plate behind the water inlet.
tazrig
Here is an enlargement of the eBay pic limitout posted for you:
MH Hawker
Part 12 and your link looks like the correct one, but i bet your is ok, its above the prop under the cav plate.
