Huntaholic
Thread starter- Joined
- Aug 13, 2007
- 6
New member here, was referred on another forum.
Here's the skinny:
2003 Skeeter ZX200
Motorguide Tour Edition Trolling motor, 36v/109lb thrust (Model #7109v)
Charging System International, Four Bank Pro SE (Sportsman Edition) charging system
Two Dual Pro Charger Remote Charging indicators for battery charge level.
Each indicator will read two batteries, so I have Indicator 1 on Battery 1 & 2 and Indicator 2 on battery 3 & 4
I had two trolling batteries go dead and the third was fine (at least when we tested it). I bought two batteries and installed them. As I took the leads off the existing dead batteries, I zip tied them through the ring terminals so I could put them back on easily and wouldn't have any crossed wiring. I put everything in and checked my four pro and I've got two batterys not even showing up on the Banks LED's or the Remote LED's.
I looked at the LED readout for the Banks, nothing.....
I looked at the banks for the charge indicator. Battery 1 and Battery 4 (motor) had LED's reading but 2 & 3 showed nothing.....
I have the batteries trolling batteries wired in series, and here's how everything is wired:
Main Cables to trolling motor plug:
Red (from Trolling motor) to Battery 1 Red (+)
Battery 1 Black (-) to Battery 2 Red (+)
Battery 2 Black (-) to Battery 3 Red (+)
Battery 3 Black (-) to Trolling motor
Battery 4 - Starting Battery/electronics (dual purpose)
Cables from Banks 4 Pro Charging system to Batteries:
Cable 1: Red (+) to Battery 1 Red (+); Black (-) to Battery 1 Black (-)
Cable 2: Red (+) to Battery 2 Red (+); Black (-) to Battery 2 Black (-)
Cable 3: Red (+) to Battery 3 Red (+); Black (-) to Battery 3 Black (-)
Cable 4: Red (+) to Battery 4 Red (+); Black (-) to Battery 4 Black (-)
Cables from Banks LED Readout to Batteries:
First Cable 1: Red (+) to Battery 1 Red (+); Black (-) to Battery 1 Black (-)
First Cable 2: Red (+) to Battery 2 Red (+); Black (-) to Battery 2 Black (-)
Second Cable 1: Red (+) to Battery 3 Red (+); Black (-) to Battery 3 Black (-)
Second Cable 2: Red (+) to Battery 4 Red (+); Black (-) to Battery 4 Black (-)
From everything I know about wiring this is all correct, it just seems that I took something off and it went Murphy on me. Maybe a loose connection or one of those in line fuses giving me fits, but I've checked everything and even went as far to remove all leads to all four batteries, rearrange them and wire them independantly to make sure I didn't have a cross, run the series wire and still nothing on the indicators.
Anyone got ideas on what happened?????
Also when I put the meter on the batteries, I get 12 volts on each battery independantly and 36 volts when in series and I do not have a switch that goes from 24-36v or from 12-36v.
Anyone got an idea on what's going on???
All ideas will be welcomed, since I can't think of anything!!
Here's the skinny:
2003 Skeeter ZX200
