Another boat restoration
Dennischaves
Well what can I say
here I go again
with all the help from you fine folks on my Glaston V196
i decided to do another boat
this time it’s a bayliner trophy 1910 center console
first off horrible workmanship the tabbing all came off with a prybar with little effort and of course all the wood was rotted
this boat was built rub style so the deck was tabbed in from the bottom and it was just suspended or floating with some strips of wood gunning across to stiffen it
the stringers did not support the deck
my big question is should I put the same size stringers back or make them bigger so the deck rests on them ?
im worried if I don’t the deck will flex too much even with 3/4 ply
the original stringers were 1x3 and I’m going to have to use 1x12 lumber if I want them to support the deck
i need some input and advice here
I also left 2” around the perimeter of the deck to rest the new ply deck on and to tab it in
Dennischaves
Forgot
the picture
kcassells
Noooooooooooooooooooooo not another Bayliner……………...………
Only kidding, looking forward to your new project.
You answered your own question.
use 4# foam to help stiffen the hull
Dennischaves
Kcassells I know I was going to catch hell for a bayliner 🤣
but The price was right FREE
so you think it will flex too much too
i know older maco center consoles were built the same way
kcassells
I think Scott is correct, The foam is a major player for strength for that style boat.
You could go back with 3/4 ply. The lip is what I did too, Loved how it worked out. Some of that wood was rotted and I picked it out and added new in between old glass. Then attached another lip under that to pick up the new deck.
Add a bulkhead then you will be able to use 8' sheets of ply for stringers.
Woodonglass
Honorary Supreme Mariner
The boat never had foam as a structural part of the boat
And that's why Bayliners suffer!!! A TUB type liner needs the foam for structure and safety. If you don't use foam then I would agree that the stringers should be extended for support. I'd also double up on tabbing to increase strength to minimize flexing of the hull.
Dennischaves
Looks like I’m sticking with the original plan
stringers all the way up to the deck
my stringers are about 13” tall and 12’ long
I’m planning on making them from plywood because directional lumber is hard to find in that size
my next question is
what thickness ply should I use and how many layers
and is there any specific way to make the joint of where the two plywood ends meet?
Dennischaves
Won’t that be a weak spot at the bulkhead ?
just 1 layer 5/8 ply?
steve_h7
Fwiw I layered 2 - half inch strips of ACX plywood glued and then clamped between a couple of 2 x 6's arranged like this for my stringers:
kcassells
Like Steve said:
All good there with your method!! Structural ply over dimensional lumber is the ticket.:joyous:
