another compression question
Dawgs
will there be different reading with the same motor if i do a compression test with the motor in the back of my pick-up....then do the same test with motor on the boat all hooked up and ready to go?
wilde1j
Re: another compression question
Not if you remove all the spark plugs for either test.
Dawgs
the reason i ask is...im just figuring if its all hooked up it will have a secure ground...better crank...etc.....no?
wilde1j
I have no idea what motor you have and no idea why you would not just check it on the boat.
Dawgs
i have a 1990 johnson 150...the reason im not checking it on the boat is because its in my pick up. i tested it in my pick up and got 70 psi on all 6 cylinders but it seemed low
JB
Dawgs, 60psi is not unusual for a big OMC V6 and does not indicate a problem. 70psi is even better.
So many factors affect compression readings that you might get slightly different numbers on the transom, but that would not indicate a problem either.
Dawgs
i cant seafoam it unless its running...correct? i need to mount it then hook it all up first
Dawgs
call me stupid....but what does "OMC" mean?
wilde1j
Outboard Marine Corp., the parent of Johnson and Evinrude divisions. OMC bellied up in 1999-2000 and BRP acquired the assets of the bankrupt firm.
