Coral Grimes
Thread starter- Joined
- Feb 27, 2017
- 5
First time poster...thanks in advance for your help.
My father gave me a 2000 Sylvan Explorer that needed a lot of work. It has been outside, uncovered for a couple of years. Over the past couple of months, I've practically stripped the entire boat. My plan is to take off the outboard and go with a trolling motor only set up, as most the lakes by me are electric only.
My question at this point (and I'm sure I will have plenty more) is whether I need to remove the existing foam. After pulling up the plywood floors (which needed to go), the foam actually looks good. See the attached pictures. The discoloration seems to be more from the plywood sitting up against the foam. It actually took a significant amount of prying to get the boards up. However, the foam seems very solid and not water logged at all. That being said, the boat has been in my garage for five months or so...i.e., plenty of time to dry out.
Can I leave this foam in place and just replace the boards over top of it? There are a couple of spots where I accidentally cut the foam or pulled off little sections. Should this impact my decision?
