another impeller replacement question
kenny80
im replacing the impeller on my alpha 1, now when i took the casing down it didnt have the rubber centrifugal slinger on the shaft, my kit came with one so thats no big deal, but im not so sure its not inside where the shaft goes. it looks like a brass sleeve with a very thin rubber lining on the edge. and it sure wont pull out.
Bt Doctur
Re: another impeller replacement question
post a pic, it sounds like your looking at the brass insert for the impeller minus the rubber vanes. the rubber slinger goes on the top of the upper pump housing.
kenny80
i will try to post a pic tomorrow. it does go over the shaft that comes through the pump housing. the brass deal im talking about is inside the other housing where the shaft slides in.
kenny80
think i got that problem figured out, but i noticed a piece of metal with a rubbery coating on it behind the prob that seems to be jammed inside. if it is supposed to be there my best guess would be an anode? im gonna try to post a pic of it.20120301123613.jpg
Bt Doctur
guessing its whats left of the exaust shutter that was in the Y pipe
kenny80
is it important? it is jammed in there tight so im pretty sure its not going to dislodge its self. and do i have a y pipe on a 4cylinder?
Fishermark
is it important?
It is designed to keep water from backing up into the engine through the exhaust ... it would only happen under certain situations. Many boaters go years without the shutter(s) and have no problems. The choice is yours.
No. But you do have an exhaust pipe. "Y pipe" is simply a common way of talking about the exhaust pipe. Inline engines have the single pipe, while the V engines have the Y pipe.
dubs283
if you leave it in there, it will come out on its own eventually, then may get wedged in your prop while under way, or end up somehow damaging the retainer or carrier
you can bend the shutter to get it out of there, or try pushing it back into the cavity and fishing it out
as far as replacing the part, it is fairly simple, just remove the riser and exhaust boot and install a new one
if the swivel pin has fallen down into the exhaust pipe and lodged in there it WILL eventually rub a hole in the pipe
achris
More fish than mountain goat
...if the swivel pin has fallen down into the exhaust pipe and lodged in there it WILL eventually rub a hole in the pipe
And fill the boat with water, usually when you are more than 30 miles out to sea... Don't ask me how I know this... :facepalm: :D
Chris......
kenny80
ok thanks for the info guys, ill go try to remove it.
