Another Kill-Switch question...
tgaffron
Maybe you guys can help me...
I have an 84 Johnson 35hp electric start/tiller that cranks fine, seems to be getting gas but won't fire. Thinking that something is bad with the pushbutton kill-switch. If I test it with a multimeter should the circuit be broken when putton is not pushed, or should circuit be complete when the button is not pushed? Should I take the wires off the switch to test it so I am not getting a complete circuit the other way through the engine and fooling myself?
Thanks for any advice!
Tim G. in MN
Barnacle_Bill
Re: Another Kill-Switch question...
You should have an open circuit until the button is pushed.
Silvertip
Or another way to put it -- the engine requires and OPEN kill circuit in order for it to run. Pushing the button closes the circuit shorting the ignition to ground thus killing the engine.
