another new boat looker...
109jb
Re: another new boat looker...
I/O vs Outboard
The I/O requires winterization if you live where temps get below freezing or you risk a busted block or other. The outboard can simply be placed in the lowered position and all of the water inside it will drain.
Motor replacement of an outboard is obviously easier if something happens that requires a new motor.
I/O's reguire periodic replacement of the bellows to prevent leaks into the hull
I/O's have gimbles that wear out and need replacement whereas an outboard doesn't have them.
An I/O has a big hole cut in the transom below the waterline for the outdrive to pass through.
I/O's have the potential for fuel and coolant leaks within the bilge area of the boat.
I/O's require bilge blowers, most outboards don't.
I/O's are more efficient than 2-stroke OB's
I/O's are more environmentally freindly compared to 2-stroke OB's.
I/O's don't have a motor sticking up in the air.
Outboards don't reside inside the boat.
Used I/O's appear to be cheaper to acquire than a comparable horsepower OB boat.
I personally prefer outboards and on the 3 I have owned, I have had no maintenance costs other than what I do for storage. For winter storage, I do the following:
1. Last few tanks of fuel for the season are treated with Sea Foam or Sta-bil per instructions.
2. After last outing, I put the muffs on, run engine and fog it
3. Park boat and plug in battery maintainer
That's it. In the spring I do the following to get it ready:
1. Clean air cleaner and install
2. Start it up
3. Hit the water
4. Run sea foam for the first couple tanks.
This has worked for me for the past 10 years with no problems. Other than storage, I have only had to replace spark plugs.
I also like outboards better for fishing in shallow waters, but it can be argued that without the motor sticking up you can work the fish better, but then again, the motor hood hampers that on an I/O.
I'm an outboard man myself, but may be acquiring an I/O for free from my dad. It hasn't run in many years and If I can't get it to I will probably convert it to outboard power.
ckone0814
awesome info! thanks!!!
ckone0814
I'm looking and looking but I keep coming back to a 98 20' Sprint Fish and Ski that's right down the road from me. Haven't looked at it in person yet but it looks great in the pics and is pretty much loaded for $11k obo. It's a lot like the Nitro in style and function I'd say.
It has a 200 hp Yamaha ob which seems like a lot of power to me. Is it? I know some places have hp limits; would that amount of hp severly restrict where it could be used?
Sprint is apparently out of business. Should that concern me negatively for parts etc. or positively for price negotiation? Should it even concern me at all?
ezmobee
Places that limit horsepower are usually limiting it to like 10. So pretty much any boat you're looking at is not going to meet that. I've never heard of a place where the horsepower was limited to like 150 or something. So don't worry about that. I also wouldn't worry about the boat builder being out of business. Boat designs change so much from year to year that you'd probably have just as much trouble finding parts for a '98 Sprint as a '98 SeaRay.
