Another Newbie in need of help!!!
Ladder12
My wife and I purchased our first boat earlier this year. It seems that my bosses father-in-law had passed away and they were trying to get rid of a 1989 Sea Ray 180 Bowrider. Well, we went and looked at it and, for only $300, it seemed like a great deal.
We got the boat home and started to clean it up. The flooring over the gas tank (between the seats) was very soft so we decided that we needed to replace it before we went out. During this process we realized that there was alot more that needed to be replaced but felt like it would get us throught the season as it was and that we could fix it up this fall/winter.
The problem now is that everytime we go out, I find more and more large
(3-4" long) pieces of rotten wood in the bilge area. With that even a novice boater like me can figure out that there is more wrong than simply the flooring. I have been reading the various threads about other renovations and assume that I we will need to strip it down to the hull and re-build it.
What I am looking for is a some information to prepare me for tackling the renovation of the boat. Is there a video, book, etc. that details how the flooring and sub-structure is installed? Also, what tools will I need and what is the approximate cost of a project of this scope?
The real part that scares me is that too much of the existing structure is rotten and can not be used as a template to make a new one. I want to spend this summer researching and preparing myself so that I am ready when the time comes.
Lastly, since there is a good portion of the flooring is soft and I am finding the rotten pieces of wood in the bilge, is it safe to operate the boat at this point. It runs great and I have not had any problems, but I don't want to take the family out and have it break-up and sink because the inside structure was rotten and allowed the hull to flex too much.
Any help would be greatly appreciated.
Woodonglass
Re: Another Newbie in need of help!!!
Welcome to iBoats! Some important questions here!!!
What size of boat is this? What size of Motor? Is is an Inboard or Outboard Motor? What style of Hull? Is it a V Hull or a Tri Hull? Is if Fiberglass or Aluminum. How much weight are you putting in the boat? That includes passengers and gasoline and cargo. How old is the boat? Does the Transom (that is the Back section of the boat that the motor is attached to) have any noticable flex in it? Is there any water in the bilge? Can you post pictures?
Have you cut any exploratory holes in the deck(boats don't have floors) to see what is below the soft spots? Cost of repairs is dependent on how much has to be done. Most likely stringers and transom and deck Cost will be some where between 1 and 2 thousand and about 100 hours of work. You can do it and you will have all the help you need from the guys here on iBoats
Give us some answers to work with and we WILL help you.
:D
zip34788
Thankfully, it is a SeaRay. Having owned many SeaRay's, I can tell you that even with rotten wood, you most likely still have a solid boat.
It has often been said that a boat is a hole in the water in which you pour money. Nevertheless, it can be rewarding in may ways. Don't despair, I am sure you will find many who can offer you good advice and assistance.
:redface:
