I'm sure this is a stupid simple question for most of you, but I am way to new to boating and hope you understand. I have a 1974 Sea Ray SRV 190. It has the Mercruiser 888 drive with the 302 Ford engine. Over the winter I picked up a used lower unit which appears to have not much use and the seller stated was his fathers and should be in good working order. I replaced the water pump unit in it and am ready to reinstall on the 888 upper. I have the unit in the forward gear position. What I need help with is making sure I have the shifter in the right position for forward for the reassembly. The shifter on this boat is a single lever that is round at the base of the lever with a single button in the center. It says Merc Control on the round part of the lever. What I don't know is the positions the lever should be in ( in or out ) for just shifting and for just throttle control. I don't have a manual on this old timer, and can't find one either. I did try using the search feature first, but no luck there. Any help would be appreciated.
