I have a 12' jon that I plan on repainting. I've read a lot of posts and am pretty much confused. I want the boat to be an OD green inside and out, nothing fancy. I had planned to pressure wash off all the paint I could, then remove the rest with the scotchbrite pads, then prime with a self-etching primer and then paint with Parker's Duck Boat paint. Will this work? Also I've read some stuff about preventing corrosion when replacing transom boards. Is using SS bolts enough? What's 5200 and I've also read to use grease? Does it matter what type of grease? Thanks, any help is appreciated.
