First off, thanks to those helping diagnose my " motor does not start issue". Replacing a 6 AWG battery cable solved that issue.
Before that no start issue I had been diagnosing why #4 cylinder does not fire.
Four fresh Champion QL77JC4 spark plugs in motor.
#4 spark plug has spark when grounding to outboard block.
A couple things. After running motor, All spark plugs are really wet with fuel. Is this normal for a motor this old? Did these motors waste that much fuel when running?
With #4 spark plug removed and motor running I placed a 12" x 12" piece of cardboard in front of empty spark plug hole to catch the spray that come out. Smells like fuel. I poured a drop or two that was on plug onto that cardboard and lit it with a bic lighter. Barely burned. By that I mean it took some doing to get a flame started, is this common with 2 stroke gasoline?
Secondly, with engine running I took a flame to that liquid spurting out of #4 cylinder expecting to see fire balls. Nope, substance did not ignite.
Tonight, I am going to swap #2 and #4 coil wires at power pack, and swap spark plug wires to verify if #4 coil is working properly. And if #2 will fire in #4 cylinder.
Am I dealing with a carburetor that is flooding #3 and #4 cylinders? #3 spark plug is firing, but color wise, it is much lighter than #1 and #2 spark plugs give same few minutes of run time they have on them.
Or, is this a head gasket issue? How would I check for a bad head gasket? I could start the engine with no water running, quickly pull #4 plug wire from cylinder but I don't want to eat up a impeller doing so.
Last time I checked all cylinders had compression between 116 - 126 psi. #4 had 116 psi. I do need to re-test since last checking was some time ago.
