another prop question
brown_one
i have a 19.5ft tahoe deck boat with 4.3 mercruiser bravo 1 outdrive. dry weight is around 3000lb. it has stock prop. want to know what a good prop would be for all around use. lots of cruising, fishing, and some tubing.
steelespike
Re: another prop question
To give you the best advice we need to know prop size(usually on the barrel or under the prop nut);present max rpm and speed.(GPS is best)and the max recommended rpm range.(usually a label on the motor).
Silvertip
Read the "How to get best results from your post" at the very top of this forum just above your post!!!
brown_one
was told on this site that max rpm is 4300-4800. i haven't had it past 4200 yet. will look at current prop size and let you know.
